How to build a LED bargraph to detect 0V to 5V?
jianwei
Newbie level 5
Newbie level 5
I was wondering how do i build a led bargraph to detect 0V to 5V? 0V mininum and 5V max. With the use of LM3914N or LM3916. If there are other chips then can be used, please let me know.
make led bargraph
LM3914N or LM3915 is the cheapest and easiest and widely used IC to make a 10 LED bar graph. It can be calibrated to any full scale value required with chnaging the biasing resistors. There are other Ic's like LB1405 which will give 5 LED output. TA7666 with 2 x 5 LED output etc. Good luck
led bar graph
is there any circuits that I can refer to?
bargraph circuits
how to I build a 0 ~ 5V led bargraph.
Since there are 10 led i presume, how i make increase 0.5V will light up 1 bar , 2 bar when 1V etc..
10 led bar graph
If you go thrrough the data sheet you will see that you can adjust the "Hi" level and "Low" scale redaing of the IC with external resistors. Good luck.
