iDk
Member level 2
hi. whats the best thing should i do to bring down the 5vdc (USB supply) to 4vdc without using any regulators, just by using only discrete components?
thanks.
thanks.
Beyond Logic said:Power (VBUS)
One of the benefits of USB is bus-powered devices - devices which obtain its power from the bus and requires no external plug packs or additional cables. However many leap at this option without first considering all the necessary criteria.
A USB device specifies its power consumption expressed in 2mA units in the configuration descriptor which we will examine in detail later. A device cannot increase its power consumption, greater than what it specifies during enumeration, even if it looses external power. There are three classes of USB functions,
Low-power bus powered functions
High-power bus powered functions
Self-powered functions
Low power bus powered functions draw all its power from the VBUS and cannot draw any more than one unit load. The USB specification defines a unit load as 100mA. Low power bus powered functions must also be designed to work down to a VBUS voltage of 4.40V and up to a maximum voltage of 5.25V measured at the upsteam plug of the device. For many 3.3V devices, LDO regulators are mandatory.
High power bus powered functions will draw all its power from the bus and cannot draw more than one unit load until it has been configured, after which it can then drain 5 unit loads (500mA Max) provided it asked for this in its descriptor. High power bus functions must be able to be detected and enumerated at a minimum 4.40V. When operating at a full unit load, a minimum VBUS of 4.75 V is specified with a maximum of 5.25V. Once again, these measurements are taken at the upstream plug.
