sdowney717
Member level 1
This is on my boat with twin 35 amp shore power
Talking about the shore ground to 12vdc negative junction inside the breaker box.
I have a 3000 watt MSW inverter where the 12vdc side must NEVER connect to the AC side or the inverter will self destruct.
Normally that will not happen. BUT, If a faulty appliance were to be plugged in or a wire failure, conceivably, the 2 power sources would connect with each other.
Is there a way using semiconductors to achieve DC current blocking but pass the higher voltage AC current?
I can use a power relay to disconnect DC ground to AC ground when the inverter is running.
