How to avoid Spark at relay contact ?
binu G
Advanced Member level 2
Bangalore
hi,
can any one suggest a solution for avoiding the spark at the relay contact for a AC inductor load ?
Thanks
Binu G
As far as i know you can prevent it by adding a capacitor across relay contacts but i don't have enough information about selecting its value.
Same technique is used in florescent tube light starters as well.
B) If you are using a relay to switch an AC-powered inductive load, put a
varistor in parallel with the load. The varistor voltage rating should be about
1.5 times the peak-to-peak steady-state voltage of the load.
C) Relays switching an inductive load may require a capacitor placed across
their contacts. 0.1ufd to 1.0ufd is a good starting point. If the relays are
switching an AC load, place a 100 ohm resistor in series with the capacitor.
Quoted from: **broken link removed**
Regards,
IanP
you must use a flywheel (protection) diode.
see power electronic books.
Use snabber :
connect (0.1uF-1.0uF series with 10-100 ohm) parallel with load or relay contacts.
should i connect capacitor and resistor on both phase and neutral ?
and it is necessary to use both neutral and phase through relay or only phase?
pls help
You can connect it on the load to your relay contact.
Snubber (R-C) is OK for most cases.
You can get better results with a transil or varistor across contacts.
