khanna_gunjan
Member level 3
- Joined
- Jul 18, 2006
- Messages
- 64
- Helped
- 9
- Reputation
- 18
- Reaction score
- 7
- Trophy points
- 1,288
- Location
- Nürnberg, Germany
- Activity points
- 1,699
How do i avoid Jitters
Hello,
In one of my application, i am trying to read a Output Voltage of a reed contact in the microcontroller and i am using an opto-coupler for the purpose. The problem is that before the contact is properly closed, there is these jitters there ( with jitters i mean closing and opening of the contact at a very fast rate, before it finally stablizes).
Can anyone suggest me a simple solution to avoid these jitters with few components. Also, i would like to mention that the output of the opto-copler is then read by the microcontroller and which can only generate an interuppt when it sees the falling edge of the signal and i tried to use an RC circuit at the output of the opto-coupler .. but with the slow charging and discharge time the controller is not able to detect the falling edge of the signal..
Please suggest. thanks
Gunjan
Hello,
Gunjan
