alex051
Newbie level 5
I am trying to build a grid connected inverter. And the inverter works at lower dc voltage input levels. I want to increase the voltage up 100V but when I increase the voltage above 20V the gate signals begin to be distorted and the MOSFETs are not switched when they are supposed to.
I think the reason may be because of noise interference from the high frequency switching. I used optocouplers for the gate drives to avoid this but the problem is still there.
I would appreciate it if any one has suggestions.
Thanks
Thanks
