how to assign voltages using 0-16 hexadecimal numbers
angiey
Junior Member level 1
Hi all!!
How to assign the voltages[say 7 to 12v] using hexadecimal values,since i'm using pic microcontroller i have already assigned 4 ports as v1,v2,v3 & v4
and initialized different hex values to these port numbers,so when we press any key it should set to the particular voltages.
Kindly give any suggestion regarding this.
Thanks for the information,it was really helpful.
Can you give me some hint that how this values can be stored in the program,as i'm using C code,
and for this i'm using if_else statements, it should be programmed in such a way that when we press
some button it should vary[i.e, voltages should vary].
Thanks in advance.
