TADE
Junior Member level 1
Hai friends,
I have created a heterogeneous component into 8 parts each consist of 3 pins.
in that first 4 parts has one common pin called ground 1 ,
the next 4 parts also has the one common pin called ground 19.
so i have decided to assign the first part into 3 pins the other 3 parts into 2 pins structure by removing the ground pins..
while editing ,the second part i.e while removing the ground pin.it is applied to all the other 3 parts.
I want to remove only for the second part,but it is not coming.
I want to edit one by one.
how to do this?
how to do this?
