how to approximately solve this equation?
shafee001
Full Member level 1
Egypt
there is no way to 'approximatly' solve any equassion
you either solve it or not
the above calculations isnt an equassion
it contains no equators only pure maths
so.. any good calculator will solve it easy
do it one set of brackets at a time
then multiply all answers from left to right
the best way to solve the highorder powers
is to use a good quality piece of software like mathlab
it will allow large powers ... and give a sensible answer {very accurate}
thanks for your comments
but i still know how to get the answer of it
matlab, mathmatica, calculators gives overflow error
it's a huge calculation, that's why i asked for approximitly? there may be an algorithm which i don't know it can solve? so i am still wondering?
ok if you still get overflows this is easy
just take the power and /1000
so forinstance 9646 becomes 9.646
so this would be
10E9.646 etc...
then each stage you miltiply your answers simply add the right number of zeros to your final answer 12 zeros in total need added anyway....
this calculation can be done easier on paper than machines
its realy easy to do this longhand
In what numerical format do you expect the result? To print it out using ordinary scientific notation, the universe isn't big enough to hold all the exponent digits, even using a really small font.
Let’s call x the number of your expression. Work with logarithms (for convenience, with decimal logs):
Log(x)=(5.53*10^9861)*Log[] .... an so on ....
Log(x)= (5.53*10^9861) * (1.15*10^9866) * (8.65*10^9862) * Log(1.42*10^9864)
Log(x) = (5.53 * 1.15 * 8.65) * 10^29589 * (Log(1.42) + 9864)
Log(x) = 5.42… * 10^29594
Thus, x is a really huge number. (Yet Log(x) is really huge!)
By comparison: Nowadays, the total number of particles in the universe has been variously estimated at numbers from 10^72 up to 10^87.
Where does this question come from?
Regards
Z
maybe the guy needs the big house ?
but its a serious calculation so a / by 1000 powers all over and move the decimal point is the best method
if you like my pal ill calculate the answer on paper and scan the workings...
if you like?
