How to apply the MFCC into neural network using matlab?
fikrul
Junior Member level 3
MFCC
Hello guys,
How to apply the MFCC(mel-frequency cepstral coefficient) coefficient into neural network using matlab?
Please help me on this matter...
hello bassa,
i've wrote the code to produced 13th coefficient of mel-frequency data, but im not really know how to use it in neural network? This my code that i just wrote:
load fik_1; %getting the data from directory
fs = 11025; %frequency sampling
precoeff = -0.9; %Pre-Emphasis the data signal
x = [fik_1(1)*(1+precoeff);fik_1(2:end)+precoeff*fik_1(1:end-1)];
wavplay(x,fs);
w = 'm'; %Window type's :hamming
nc = 13; % No. of coefficient 13th
p = floor(3*log(fs)); %No. of filters in filterbank
n = pow2(floor(log2(0.03*fs))) %Lenght of frame in samples = 256
inc = n/2; %frame increment (default n/2)
fl = 0; %low end of the lowest filter as a fraction of fs (default = 0)
fh = 0.5; %high end of highest filter as a fraction of fs (default = 0.5)
c=melcepst(x,fs,w,nc); %apply MFCC function to get 13th coefficient
[r,p] = corrcoef(c)
you may refer the method explained in the page 8 of the article
net=newff(minmax( X (n) MFCC ),[13 4],{'tansig''tansig'},'trainlm');
How about the target? What it should be?
if my P the input which are my 13coefficient, what is going to be for my T(target)..??
Target would be the data set which is actual, desired, taken from the system for particular known signal and input P is arbitrary input data set which is taken at run time (current signal)
You need to take same set of 13 coefficient for the signal which is need to be identified (actual signal)
Let say, your target is to identify signal \[s1\] then you need to obtain data set for \[s1\] assume your T is [0 1 2 3 4 3 2 1 2 3 4]; and need to store in memory (something called dictionary)
Now input another arbitrary signal, let say [tex:d102efd4b3]s2[/tex:d102efd4b3] to the system and obtain P = [0 1 2 3 4 5 6 7 8 9 10]; (called current print)
So for a network is created with one hidden layer of five neurons.
net = newff(P,T,5);
The network is simulated and its output plotted against the targets.
       Y = sim(net,P);
      plot(P,T,P,Y,'o')
The network is trained for 50 epochs. Again the network's output is plotted.
      net.trainParam.epochs = 50;
      net = train(net,P,T);
      Y = sim(net,P);
      plot(P,T,P,Y,'o')
In the article it is described as below
[net,tr]= train( X (n) MFCC ,T);
hope this help
regards
bassa
Helo bassa,
Why after i compile the code followed from the article, there were a lot of error?
It may be due to compiler version. you can find the correct format of the command using help so then update your program
Ex:in the matlab command prompt type "help newff" then it will show the correct format
If you can post your code then others can check it for you
this is my code:
s = wavrecord(2*fs,fs);
x = [s(1)*(1+precoeff);s(2:end)+precoeff*s(1:end-1)];
wavplay(x,fs);
c=melcepst(x,fs,w,nc,inc); %apply MFCC function to get 13th coefficient
c=cov(c);
%save c;
load c3;
P = c;
T = c3;
net=newff( P,T,[],{'tansig''tansig'},'trainlm');
net= train(net, P ,T);
Change the following two lines
%net=newff( P,T,[],{'tansig''tansig'},'trainlm');
%net= train(net, P ,T);
net = newff(P,T,5); %Here a network is created with one hidden layer of five neurons.
hello bassa,
May i know, what the value of my target should i use?
In a similar program of mine matrices w1,w2,w3 contains the MFCC for 3 speakers which are of dimension (100x10) where 100 represents the number of frames and 10 is the number of MFCC coefficients. Now how am i going to define the neural network and train it with all the three MFCC matrix? Please help me..
