dreadQ
Newbie
hello, I have some problem in STAR_RC.
I want noRC opt. but There is only RC/R/C in StarRC manual.
Below are some of the scripts I use.
* Cof hanled by PEX from V1.0 release*
** Following setting should be observed
IGNORE_CAPACITANCE: ALL RETAIN_GATE_DIFFUSION_COUPLING
COUPLING_ABS_THRESHOLD: 0
COUPLING_REL_THRESHOLD: 0
COUPLING_REPORT_FILE:
NETLIST_FORMAT:
SKIP_CELLS: !*
XREF: YES|NO
OPERATING_TEMPERATURE:
NETLIST_INSTANCE_SECTION:
REDUCTION: HIGH|YES|LAYER|NO
NETLIST_SUBCKT:
CASE_SENSITIVE:
POWER_EXTRACT: YES|NO|RONLY|DEVICE_LAYERS
EXTRACT_VIA_CAPS: YES
EXTRACT_RES_BODY_COUPLING: YES
HN_NETLIST_SPICE_TYPE: <device> X
TRENCH_CONTACT_VIRTUAL_VIA_SEGMENTATION_RATIO: 1
REFERENCE_DIRECTION:
*=> VERTICAL|HORIZONTAL, PC direction
TRANSLATE_FLOATING_AS_FILL: YES
*=> YES is recommended for Calibre LVS to StarRC
MULTIGATE_MODELS: YES
DPT: YES
*=> If DPT corner is used, this command needs to be set to YES.
*LPE_PARAM :
*LPE_DEVICES :
NETS:!
EXTRACTION:RC|R|C
COUPLE_TO_GROUND: NOCOUPLING_ABS_THRESHOLD: 0
NETLIST_FORMAT:
SKIP_CELLS: !*
XREF: YES|NO
NETLIST_SUBCKT:
CASE_SENSITIVE:
DPT: YES
*LPE_PARAM :
*LPE_DEVICES :
NETS:!
