tcwong3
Junior Member level 2
DC Amp Biasing
I need to amplify dc input voltage (ranges from 0V to 600mV) by 5 times.
Only single supply of 12V is available for my circuit.
I use op amp to form non-inverting amplifier.
It work well when the input is above 0V.
But when the input is 0V, the op amp has no bias current flow into its
non-inverting pin, the circuit become not workable. The output is almost 12V (actual value should be 0V x 5 = 0V) when Vin = 0V.
If I try to bias the input, the bias voltage will be amplified and output become not acurate.
can anybody tell me how do apply bias without affect the output result.
