svensl
Full Member level 1
![Full Member level 1](/styles/images/ranks/elevel1.gif)
Hello,
Is there any way to amplify the change in capacitance? For example, consider a capacitor that changes its capacitance with pressure, for example. The capacitor will have a center capacitance and then a very small deviation around it due to different pressures. The problem is that the deviation is very small and the circuit in which I want to use the pressure dependent capacitor is not sensitive enough to pick up this minute change in capacitance. Is there any way to amplify just the deviation in capacitance? Again, I don’t want to amplify the center capacitance as this is already big, I just need an amplified value for the deviation.
Thanks,
Sven
Thanks,
Sven
