How to adjust lens in dvd/cd players?
chetreynolds
Junior Member level 3
usa
Does anyone have a proceedure for adjusting the lens on these devices
Re: dvd/cd repairs
It rarely becomes necessary to adjust these lenses since they're factory-set with special equipment. I would suggest that you get a replacement kit for your model then you won't have to go through any adjustments. Home adjustments do not usually give reliable performance. Maybe you may give more info about your problem, e.g the fault symptoms on the dvd/cd player that you want to adjust??
dvd/cd repairs
Realy thank's. I had the same troubles with my DVD. I could not repair it without you...
