How to add zener diode in ADS ??
Re: @DS help
Hi
Use a Diode (PN-Junction Diode) and a Diode_Model (PN-Junction Diode Model).
To model a Zener diode, the Diode_Model parameters Bv and Ibv can be used. Bv should be set to the Zener reverse breakdown voltage as a positive number. Ibv is set to the breakdown current that flows at that voltage as a positive number; typically this is in the range of 1 to 10 mA. The series resistance Rs should also be set; a typical value is 1 Ohm.
//alexx
Re: @DS help
Hi, I bought a used ds (cause I is broke) and my touch screen has stopped working, is there anything I can do to get it fixed?
@DS help
create the model of Z diode first.
Re: @DS help
I have no idea what that is
