how to add ucos 2 in keil 4?
pareshdhandhukiya
Newbie level 3
Newbie level 3
i am new at embedded system and wants to know how i can add ucos 2 rtos in keil compiler ,
plz help me
What microcontroller are you using? If you navigate to Micriums website, they list a large amount of ports for various processors. Furthermore, many of the microcontrollers use Keil, so Micrium provides example projects that you can simply import and compile.
Here is the link that will take you to the page that lists all of the various ports. Once you know which uC you are using, download the the correct port and simply import the project into Keil.
https://micrium.com/page/downloads/ports
Regards,
Willis
hey sir i m using lpc 2148. when i compile the given example in keil 4 it ia giving large number of errors, i m adding the ucos 2 source file in the project as mentioned in the example but still getting lots of errors.help me
