How to add library to simulate MOS circuits in Orcad 9?
bjerkely
Member level 4
Member level 4
Turkiye
orcad??
I'm a new user of ORCAD-9 and i can'T add the library to simulate MOS circuits!!
Could anyone help me? :roll:
thanx!
orcad??
Topic moved to the correct forum.
Re: orcad??
Do you use general capture or pspice mode?
It is basic application,you can find answer in orcad help files or their application note.
Re: orcad??
You must setup a project with the pspice parts.
The PWRMOS lib in the pspice can be used to simulate MOS circuit.
Re: orcad??
This is a good tutorial that may help you
/ File deleted, use link in next post.
- ME
Re: orcad??
Always post description of uploaded files, and don't upload files that can be found on the internet, just post link instead!
This tutorial can be downloaded here, with additional OrCAD libs, BOM etc.
An OrCAD Tutorial for ELEC 424
High-Speed Systems Design
Revision 1.0 - Spring 2002
This introduction can also be found as an online introduction instead of word document:
