How to access the pci configuration space ?
malcolm_119
access pci configuration space dos
I need to test the PCI board under DOS , but I don't know how to access the pci
configuration register.
Knowing this will be of help to me in my routine.
Thanks
I haven't done that in many years, but try searching for info describing BIOS 0x1A calls such as these:
PCI_READ_CONFIG_BYTE 0xB108
PCI_READ_CONFIG_WORD 0xB109
PCI_READ_CONFIG_DWORD 0xB10A
PCI_WRITE_CONFIG_BYTE 0xB10B
PCI_WRITE_CONFIG_WORD 0xB10C
PCI_WRITE_CONFIG_DWORD 0xB10D
You can probably find example code by searching Google for some of those keywords. Here's a web page with parameter details:
http://www.delorie.com/djgpp/doc/rbinter/ix/1A/B1.html
Also very helpful: "PCI BIOS Specification Revision 2.1":
Thanks a lot !
The two links are very important ~~
use the "hardware direct" software. it can access to the config space, memory space, IO space.
I was using it to test my PCI card.
But of course, the software guys will have to drive a "real" driver.
there is a pci sniffer software, it boots instead of OS, you can read, but not write the PCI card config regs
one more thing:
in the IO space, there is a PCI config Address, and a PCI config data register. with those, you can access to the config space, in a driver software.
buenos said:
one more thing:
With your help , I have found the add. reg & data reg (0xCF8 0xCFC )
Thanks !
