How to access port using C++ under Windows XP?
HARRYNOV
How to access port using c++ under windows xp?
Re: access port
In windows XP you don't have direct access to ports.
You must write own kernel mode driver that can interfacing directly to ports or use this h**p://www.beyondlogic.org/porttalk/porttalk.htm - this kernel driver allow windows application read/write direct to any port.
access port
i has tryed that but it is not work. Can you give me a snippet program in c++ to use porttalk. i has installed it on c:\windows\system32\drivers directory and i has run ollawio.exe. thanks.
Re: access port
Why its not work? I check this driver some time ago, and all work fine. Sample sources are available in porttalk22.zip package.
Re: access port
it can be that it does not work by the SP2 of XP ... passes that to me now
Re: access port
to get direct acces on XP, Try UserPort by Tomas Franzon based on an article written by Dale Roberts 8/30/95, published in May 96 Dr
Dobbs Journal, see www.ddj.com.
or Eltima's vport.ocx , vportxp for virtual ports
Re: access port
May be you can try out the active control or IO dll at www.geocities.com/bagtool/parallel_access.html
My VB program under XP & Win2K which controlling my water heaters & lighting is working well under the activex/IO dll above.
Oh ya... please check whether your computer's parallel port is on ECP mode (bi-directional) which can be used to read or write the port. If it is on SPP mode (one way), then it can write data to port only.
heino:idea:
access port
Hi all,
i am new to programming in VisualC#.NET.
Is there any (simple) way in which i can access the COM port (read/write to XML device connected to it) using either Wndows Application (prefered) or Console Application!!
The "using System.IO.Ports" is not available in VS.NET 2003. Likewise the 'MSComm' control.
Please help.. thanks
