How to access C variables in .c files ?
JaMe
Junior Member level 1
Indonesia
I have variable called "Timer1" in file "main.c".
The problem is, is there any way to access those variable in other file, e.g, in file "init.c" ?
variable in C
Are main.c and init.c compiled into one executable?
If main() calls init(), then the call could pass a pointer to Timer1.
#include <stdio.h>
void init(int *value)
  printf(" Value = %d\n", *value);
  *value *= 2;
int main(void)
  int Timer1 = 123;
  printf("Timer1 = %d\n", Timer1);
  init(&Timer1);
  return 0;
Output:
Timer1 = 123
 Value = 123
 Value = 246
Timer1 = 246
Re: variable in C
hi
in the file init.c put
extern datatype Timer1;
this is if the variable Timer1 is global variable in file main.c
For more details check the keyword extern.
Salam
Hossam Alzomor
www(.)i-g(.)org
    JaMe
Re: variable in C
you can't access it unless you define the variable outside main function.
Re: variable in C
in "init.c"
extern int Timer1;
void init(void)
Timer1 = 0;
in "main.c"
int Timer1;
extern void init(void);
int main(void)
init();
//other codes
return 0;
Re: variable in C
The variable Timer1 should be global
variable in C
U need the extern statement. That plus the function prototype tell the compiler/likerhow to set up the call, what to return from it, what the storage spaces required are and also. extern tells the compiler it will find the function (or a variable) in another file.
variable in C
One way of doing this is to create a main.h, decalre this variable as extern and then include the main.h in the init.c file. This is needed if the compiler enforces ansi stds strictly. Otherwise, make sure that u link both files after compilation, use the extern keyword directly in your init.c file.
