This is made by a kind of printer called CIJ ( continous ink jet ), which is essencially a stream of electrically charged droplets, being continuously driven through a channel whose deflection is made by modulating high voltages between two plates ( similar to a CRT ). These equipments are not cheap, and have the advantage of being able to print even on non-flat surfaces, such as the neck of a bottle for example.
