how the this pointer works
desaipa
Member level 2
Member level 2
india
hi all ,
how the THIS pointer works
PD
The 'this' pointer references the current object, the object that the method was called from.
Consult Cpp for more clear understanding of the same.
Added after 9 seconds:
Consult Cpp ebooks for more clear understanding of the same.
Added after 5 minutes:
u said about e book which one can u send it me
PD
Think of a class as being a template for a structure (i.e., a struct typedef).
When you call a member function of a class, you are in fact passing to that function an "invisible" argument. That is to say that you won't see this argument as a formal argument in the function's declaration, nor will you include a value for the argument when you call the member function. This invisible argument is the "this" pointer, which points to a specific instance of the class'es structure.
