How the battery runtime is decreasing with increase in energy density?
khatus
Member level 3
Member level 3
Hello guys, I can not understand how the battery runtime is decreasing with increasing energy density?
As I know 03 reason:
01 - When dischare current of battery is higher, it make battery hotter. Battery has internal resistance, which heat up itself. When the temperture rising. The self discharger current also rising follow. And lost capacity.
02- Internal resistance is not fixed, it is dynamic follow discharge current. When higher current make higher lost power (relate to chemical & mechanical also). You know the lost is propotion to quare time P = I^2 x R, it is not linearity. This like "skill effect" of conductor. The ion need to exchange with electrode, more current will make more collistion between them, that make lost engerny.
03 - Charge and discharge with higher current make "boiling" effect on surface of electrode, will damage electrode little a beat. That why capacity of battery reduce eache charge/discharge time and each battery have its limit charging action to maintaince its 80% the first capacity.
To extend life time off battery, using capacitor in parallel of battery. With e-vehicle using power path control with supper-cap to support boost up power in short time and charge/save current/power from brake. Which also help to improve usefull capacity of battery.
The statement underlined in red is not accurate. The energy density and power density can be independent; in other words, you can have high energy density and high power density; high energy density and low power density; low energy density and high power density and finally low energy density and low power density.
