Well, you could read the datasheet (I think this is the one...)
If it's an opaque case, then you can use your multimeter...
The coil pins will have tens to hundreds of ohms. The closed switches will have almost zero ohms (if you have a continuity tester, use that) and once you know the coil pins, power it up and get the other side of the switch contacts with the continuity tester.
