How should I tell if the analyzed signal is real or complex?
giorgi3092
Junior Member level 2
One of the test questions had these problems:
So, I need to tell whether the signal real or complex from its DFT magnitude and phase spectra.
DFT formula is:
How should I even think about this problem? I did some experiments in Matlab and got even more confused. Any hints?
Solution
Thanks for the reply.
I'll answer my own question:
The function f is real-valued iff the FT of f is Hermitian (conjugate symmetric).
f is Hermitian iff:
a) real part of f is even.
b) imaginary part of f is odd.
Summary: for a function f to be real:
a) The amplitude spectrum must have even symmetry.
b) The phase spectrum must have odd symmetry.
source: https://en.wikipedia.org/wiki/Hermitian_function
Answers to the problem:
1) real
2) real
3) complex
DFT formula is:
DFT formula is:
Try this, change the vector test as you like: (look how amplitude/phase show symmetry/antisymmetry)
xr=4*cos(2*pi*(0:19)*0);
xi=4*sin(2*pi*(0:19)*0);
%noise
nr = randn(1,20);
ni = randn(1,20);
test = complex(xr,xi) + complex(nr,ni);
stem(abs(fft(test)));
stem(angle(fft(test)));
f is Hermitian iff:
1) real
2) real
3) complex
Solution
