dann11
Full Member level 3
How should I monitor the output voltage of a boost converter?
for example I have a boost converter with output voltage of 60V +/- 5Vand I have a voltage sense that sense the change of these value, should my voltage sense monitor the levels above the its maximum or below its minimum level? anyway the voltage sense is used to switch the PWM controller on and off.
