how plc generates the analog signal (speed signal) to the VFD ?
phatcreators
Full Member level 5
Full Member level 5
I want to ask from you that , how plc generates the analog signal (speed signal) i.e. analog signal to the VFD ?
What input(s) or thing(s) are required for PLC to generate the speed signal to the VFD ?
Do you mean the input of the VFD? Normally, VFDs have serial inputs (BUS, RS-485, PPI, etc). So you can configure the PLC to send a value that would represent the speed of the motor at a given time (as well as many other things).
The VFD does all the job (initialization, startup, run, stop) based on the commands recieved from the PLC.
would you represent any plc programming in that fashion ? how it represents the speed of the motor
