How much value is needed to block RF signals!?
How much attenuation (in dB) can be regarded as "blocking" in your opinion? Why?
Did you check which reactance amount can be achieved with available components (e.g. by reading a datasheet)?
Yes, but you didn't specify how much "blocking" would be required. I guess, you didn't even think about, if a choke is required at all,
if the existing series resistor can provide sufficient attenuation of RF, or if and why a certain RF level can be expected as problematic
for the circuit. You actually know very little about the said circuit.
50k inductive reactance at 80 MHz is ridiculous...
