how much long cable i can use with keypad with out emi ?
d@nny
Full Member level 5
Full Member level 5
hello
how much long cable i can use with keypad as below schematic ?
The frequency and current are low so you should be able to use long wires but the question is how far do you want to go?
Alex
circuit is working on 5v dc . the frequency is 8mhz. i just want to know the very reasonable length with no error .
8mhz is the frequency of the mcu core, the frequency that you scan the keyboard is much much lower
Alex
how much log wire i can use ?
