delwin
Newbie level 6
Hello, I have some beginners questions about VFDs.
I'm planning to build a VFD for a ACIM, the motor is 3-phase, rated - Delta/Y 220V/380V(RMS). I'm going to use it in star configuration.
The mains supply is 220V single phase.
Now the question is, how much should be the DC Bus voltage, that feed the 3-phase inverter?
I'm going to control the switches (I assume IGBTs) with a PWM generated by a dsPIC, but the bus voltage is unclear to me.
Should 400VDC be enough, or should it be something like 560+VDC?
Please help, info on this subject is quite unavailable, especialy when it is non US(110VAC) setup.
10x in advance.
10x in advance.
