[SOLVED] how much current the dsPIC33 I/O pins could sink ?
yzou_ua
Member level 5
Member level 5
I'd like to feed 24mA current signal back to dsp. Is it ok?? Or I need an interface ?
Look in the 'Electrical Characteristics' in the data sheet of your device.
Some pins sink/source 4mA
some 8mA
and the PWM outputs 16mA.
You need a buffer.
Reactions: yzou_ua
    yzou_ua
As 2 the "PWM outputs", u mean the motor control module, right?? If so, 16mA is pretty nice!! Can u give me a link to confirm this ? Thx a lot!!
some 8mA
You need a buffer.
look on Microchip's web page for the data sheet on your dsPIC
for example, if you go to the dsPIC33FJ128MC802 web page
dsPIC33FJ128MC802
and download the data sheet - section 31.0 ELECTRICAL CHARACTERISTICS states
Maximum output current sunk by any I/O pin(3) ....4 mA
Maximum output current sourced by any I/O pin(3).........4 mA
Maximum current sunk by all ports ......200 mA
Maximum current sourced by all ports(2)...200 mA
Reactions: yzou_ua
    yzou_ua
Thx a lot, Horace1.
Btw, by"ports", you mean the analog inputs (A/D)??
dsPIC33FJ128MC802
