How long will it take to shift an 8-bit number into 8-bit serial in, parallel out?
phoenix_pavan
Banned
Junior Member level 2
How long will it take to shift an 8-bit number into 8 – bit serial in, Parallel out shift register if the clock is set at 10MHZ?
Re: register question
For SIPO it takes 8 Clk pulses
For SISO it takes 15 Clk pulses
For PISO it takes 8 Clk pulses
For PIPO it takes 1 Clk pulses
So for SIPO the output will be available at 8th pulse that means the answer is 800MHz is that right basha ji?
Added after 1 minutes:
sorry 800ns!
