How LM317 regulates the voltages
smhn72@gmail.com
Member level 3
Member level 3
I want to connect the three Pins of LM317 to take a 3v DC and facing trouble to connect the PINS in this way that it will give me 3v
i have a step down transformer of 15v 3ah and i have used a brige rectifier to convert this 15v ac in to DC and now the main issue is that i want to convert this 15v dc to 3v dc
for this i m using LM 317
Plz any body help me how i can regulate this 15dc to 3dc the voltage
Use this scheme **broken link removed** and calculate the resistor for 3v.
I suppose there is a capacitor after the diode bridge.
All your required information is in the LM317 datasheet:
Fairchild: www.fairchildsemi.com/ds/LM/LM317.pdf
TI: www.ti.com/lit/ds/symlink/lm117.pdf
From the Fairchild datasheet:
From the TI datasheet:
