how LDPC encoder/decoder works?
aravind
Advanced Member level 1
india
ldpc encoder implementation algorithm
hi friends
if anyone works in LDPC encoder/decoder design . or already implement it
can u please share which encoder /decoder algorithm is good fast implement in hardware.
thanks
regards
aravind
pg ldpc
Hi aravind,
some links.. just checkout
bit flipping decoding ldpc
Encoding is simple. Decoding is hard. Uses message passing algo. Can give papers if needed.
Salam
My BS project was in LDPC. in some case of LDPC code, encoding is very easy. in this case LDPC code generate by just LFSR(Linear Feedback Shift Register) like cyclic code. In this case some kind of Geometry code (EG and PG) are LDPC.
But decoding ?
LDPC codes have 3 method for decoding.
1- using Majority Logic gate 2- Bit Flipping 3- Belief Propagation or Sum Product(Message Passing).
Method 1 is very easy but not very good performance.
Method 2 is the modest method in complexity and performance.
Method 3 is very complex but very good performance.
I suggest method 2 for hardware implementation.
I have 1 good paper for all 3 method. tell me if u want.
Nice to see delated reply. Useful also.
M_llaa can you please share that paper with us. Let me know did u work on VLSI implementation on it.
Thanks
Aravind
Salam
My BS project was just researching not imlementation but i am familiar with it. then my suggest is Bit Flipping (BF) but i think implementing Belief Propagation (BP) is valuable work, then if u can try it.
Could U please share ur references.
Thanks in Advance.
Added after 6 minutes:
m_llaa said:
Salam
But decoding ?
How about Modified Min-Sum algorithm or extended Min Sum algorithm for Hardware implementation.It seems their performance is better with a slight increase in complexity of implementation.
Can you share ur code.
Re: bit flipping decoding ldpc
Can you please share your references for encoder/decoder.
Thanks in advance,
Tanmoy
---------- Post added at 07:30 ---------- Previous post was at 07:27 ----------
Salam
But decoding ?
Is it possible to share those papers.
Thanks in advance,
Tanmoy
As. SALAM Wa Alkom
Hi M_all
I need the paper for Understanding of Encoder and Decoder of LDPC. As you mentioned in you message (msg given below.)that u have a paper. also if you can send me your BS Project thesis to my understanding in LDPC.
I am waiting for your reply.
But decoding ?
TC
***** HAFFIZ
Naveed
Can you please share me the paper you have. Thanks in advance.
Best Regards,
Tanmoy
As. SALAM Wa Alkom
Hi M_all
But decoding ?
TC
***** HAFFIZ
Naveed
