How is this TOI output solved graphically ?
STOIKOV
Full Member level 4
Full Member level 4
graphical solution
how is solved TOIoutput graphically ? Read that intermodulation products rise 3 times faster than IF tones (so slopes rate is 3) but do not have clear why TOIoutput=1.5*m1-0.5*m2
Re: graphical solution
it's only a simple solution of linier equation
for 1st line which slope =1
YTO1 - m1 = XTO1 - X1
for 2nd line which slope = 3
YTO1 - m2 = 3 (XTO1 - X1)
where (XTO1, YTO1) is the intersection point of 1st and 2nd line.
from those two equations, an elimination can be done.
YTO1 -m1 = (YTO1-m2)/3
2/3*YTO1 = m1 - 1/3*m2
YTO1 = 3/2*m1 - 1/2*m2
hopefully it helps
regards
    STOIKOV
thanks masadi, your process to get TIOoutput is clear. This equation is in function of m1 and m2, I tried to obtain TOIinput also in function of m1 and m2 (without involving other variables) but cannot get it so far :|. Can help with it ?
Regards,
well, found in books that TOIinput=½(m1-m2)+PIN
also assuming that slopes ratio is 1:3 (see figure)
but wonder if can be obtained only in function of m1 and m2.
