How is it possible to have any intrinsic carrier concentration in a semiconductor?
sarathgpk
Newbie level 1
Newbie level 1
If the rate of generation=rate of recombination at equilibrium,how is it possible to have the presence of 1.5x 10^10 electrons and holes in an intrinsic semiconductor(Silicon)? Shouldn't they also get annihilated by recombination?(Since they were thermally generated, in equilibrium, there should be an equal and opposite process like recombination to nullify them.If they still exist, it means that generation rate somehow dominates recombination rate and the very existence of equilibrium is at stake.)
can you tell us more about how they are created for that itself provides an answer to your question
the disturbance in the form of temperature rise causes them
at absolute zero there is perfect equilibrium and so there there is no probability of finding an electron or hole in a Si molecule structure
above the 0K mark the minimum energy is sufficient to keep the molecule in equilibrium and have electrons and holes
equilibrium is just a position or state where the system posses minimum energy at room temperature SAY 300K the minimum energy allows the presence of electrons and holes in intrinsic Si atoms
sarath,
You propose some conditions, and then ask a contradictory question. If the R-G rate is at equilibrium, as you state, then how can the G rate be greater than the R rate if you just stated they are the same? If I own 12 electrons, and acquired one electron/sec and lose one electron/sec, why would I not have 12 electrons as long as my gain/loss rate stayed the same?
Ratch
Only RATE is same.
what already was there as free electrons remains there
yeah rate of recombination is same since we have a ambient room temp of 300 K the amount of free electrons still remain above the fermi level at all time
