How IC is constructed ?
my_books
Full Member level 5
Full Member level 5
How Integrated Circuit is constructed ?
This process is very complex, but if you want learn about this topics, i can recommend the book "VLSI Engineering" by Dillinger. "Microelectronics Circuits" by Sedra.
    my_books
vlsi technology by sze is a very good book. It deals from the starting stage SAND to full customed IC....
    my_books
Which Subject is helpful in IC construction ?
learn vlsi and you would know more.... i have a video of the process i would try to upload it for you
    my_books
how ic is constructed
the name itself suggest integrated circuit the circuits which is to be integrated in a small chip.
using the transistor gates and for this we use VLSI technique.or we can also use VHDL.
u can find the books on net for VLSI and for VHDL i suggest J Bhaskar is good book.
    my_books
In semiconductor device design, a floorplan of an integrated circuit is a diagram of the actual placement of its major components within the chip area. The image below is a mock chip floorplan, shown in a VLSI layout editor window.
    my_books
In same way like PCB...
but in micro-level...
IC processing is depend on technology (CMOS,NMOS), wafer size, Gate or array of logic...
and then it gets placed,routed,SI testing and thermal testing
tom
    my_books
for construction starting from the silicon wafers till the complete IC ...any book in IC fabrication and technology will do
    my_books
