[SOLVED] How I change the compileSdkVersion in build.gradle
BiNa2605
Full Member level 3
Full Member level 3
VietNam
Hi everyone,
I have an android project and I want to change the SdkVersion in build.gradle file. How can I do that?
apply plugin: 'com.android.application'
android {
    compileSdkVersion 22
    buildToolsVersion "22.0.1"
    defaultConfig {
        applicationId 'it.polimi.deib.p2pchat'
        minSdkVersion 19
        targetSdkVersion 22
        versionCode 1
        versionName "1.0"
    buildTypes {
        release {
            minifyEnabled false
            proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.txt'
    compileOptions {
        sourceCompatibility JavaVersion.VERSION_1_7
        targetCompatibility JavaVersion.VERSION_1_7
    productFlavors {
task wrapper(type: Wrapper) {
    gradleVersion = "2.5"
dependencies {
    compile fileTree(dir: 'libs', include: ['*.jar'])
    provided 'org.projectlombok:lombok:1.16.4'
    compile 'com.android.support:appcompat-v7:22.2.1'
    compile 'com.android.support:support-v4:22.2.1'
    compile 'com.android.support:recyclerview-v7:22.2.1'
    compile 'com.android.support:cardview-v7:22.2.1'
    compile 'com.jpardogo.materialtabstrip:library:1.0.6'
For example I want to change Sdk version 22 to version 16.
I strongly recommend you create a new design at the new IDE version instead of try doing that manually, due to the unknown dependencies differences from each build revision.
I fixed. First one I change the minSdkverion (after that I sync gradle button) and also modified in AndroidManifest.xml file.
