how i can match my diffrential power amplifier with a 50&amp
rezaee
Full Member level 2
Full Member level 2
matching question
how i can match my diffrential power amplifier with a 50Ω output load?
matching question
you can add impedance matching network at the ouput.... S parameter simulation might be helpful ....
    rezaee
Re: matching question
thanks, please describe me more about the possible topologies that i can use in the output of diffrential amplifier ??
when i do s-parameter simulation how i can recieve the best impedance matching network?
matching question
I used ADS(advanced design system) previously to match 50 ohm impedance. ( I m not sure which simulation tools u r using..)
You can use the termination provided by tools itself to match you input or ouput impedance..... we preferred LC matching network..
you can use smith chart while doing s-parameter to match your ciruitry more precisly.
