how i can install a linux application with an exe extension
binu G
Advanced Member level 2
Bangalore
hi
how can i install an application, for linux which have an extension exe.
it indicatie it is a binary file
how to execute it
binu g
Re: how i can install an file with extension exe in linux re
Install some PC emulator like vmware for Linux or wine...
Any reason starting a new thread again? You already asked similar things at:
Probably it is an elf file even if it has an "exe" extension.
Give it the executability: chmod +x <namefile>
Try to run it with : ./<namefile>
If it is a linux binary it should run.
Instead, if u are trying to run a windows bin, use some windows 'emulator' like WINE,bochs, etc....
Cheers.
Fib
Simple to find out, just do a:
file filename.exe
it tells you then what it is (o;
like:
me@pc:~> file windows.exe
windows.exe: MS-DOS executable (EXE), OS/2 or MS Windows
or a linux executable:
me@pc:~> file `which more`
/bin/more: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), stripped
h**p://
please dont mistake,
i have got a linux program with exe extension.
the link u have provide is that different.
in that i mean a win based program to install in linux.
here iam asking for installing a linux based program having an extension exe.
binu g
