how i can do a array of various data types with classes???
MACS
Newbie level 3
Newbie level 3
i need to do a data array of various data types (int, double,char) using classes... If there are some skilled programmer please help me...
Re: how i can do a array of various data types with classes?
If you are using C++, there are 3 chooses:
1) you can write the class by using template.
2) you can use Standard Template Library
3) If you are using Visual C++, you can try MFC collection classes
It depends on what you want to do!
Do you want to put different types into one array or do you want to make/use a general container class?
When you want a general container class, you should look at the stl (standard template library)
vector, list, map, set, ...
https://www.sgi.com/tech/stl/Vector.html
https://www.sgi.com/tech/stl/List.html
More info: https://www.sgi.com/tech/stl/table_of_contents.html
For the "different types into one array", perhaps you could use inheritance and create and "array" of (pointers to) the base class?
Be carefull with memory leaks ;-) C++ doesn't have a garbage collector by default!
Antharax
