You cannot control it by MCU directly except for the MCU built-in LCD controller.
Otherwise, you need the standalone LCD controller to handle this kind of LCM.
Such like the Seiko Epson's S1D13700FLCD Controllers (S1D13xx Series) will be suitable for it.
I'm sorry, that is wrong! PG320240 can be controlled directly from MCU, as PG320240 has build in LCD COntroller.
Please take a look at this Powertip PG320240 Interface Specification
The **broken link removed** is not built-in LCDcontroller, but the **broken link removed** has it.
And most of **broken link removed** have not built-in LCD controller.
BTW, your **broken link removed** is used for LCD controller, not for MCU.
The MCU has not enough speed to generate the these signals for scanning LCD.
Well, please check **broken link removed** **broken link removed** to know how to handle DB[0..3],FLM,M,CL1,CL2.
If your LCM without buit-in LCD controller like you pointed or **broken link removed**
No PIC has ability to handle these DB[0..3],FLM,M,CL1,CL2 signals by code.
But if your LCM with built-in LCD controller like **broken link removed**
Any PIC can do it (if it has enough pins) for A0,RD#,WR#,DB[0..7],CS#,RST#.
Sure! You can build your own LCD controller by CPLD/FPGA with embedded/external 320x240x1 bits RAM to meet the timings for LCM and MCU/MPU. But that could be more cost than a standalone one.
You can consider the LCM built-in LCD controller or MCU/MPU as like as Freescale DragonBall/i.MX series.
I have reed the datasheets how gave me in the previous posts and also the datasheet from Powertrip site. I have got some questions to do. First some pins in these datasheets have got different names functions like FLM, M. For example the FLM in the Powertrip datasheet is “Shift direction select” and in the other datasheet is “Indicates the beginning of each display cycle”. What is the difference or it is the same function with other words?
The second question is about the Supply pins. I can understand the Vdd, Vss, Vo but what about the Vee (=Negative voltage input)?
Also what is the function of FG (=Frame ground) and D-OFF (=Column output control)
I will be glad if I have got any other info about how I can control these LCDs
