how I can compensate for this 0.4V power loss
EDA_hg81
Advanced Member level 2
My idea is the input 12V can be controlled to realize power on sequence.
Why the output voltage at “out” node only can reach 11.4V?
I need 11.8V at least how I can compensate for this 0.4V loss.
Thanks..
Thank you, please give me a little more detail.
I fixed this, the values of feedback network is wrong.
If the gate is fully driven to ground (or max rated Vgs)
then it must be a MOSFET on-resistance vs load current
problem. But you'd have to inspect for that to be sure.
If so, then spec a MOSFET whose RON at your load current
gives you less than the max allowed voltage drop.
Seeing "MOSFET-P" as the device callout makes me think
you are using a small-signal MOSFET where a proper
power MOSFET is really wanted. Go to IR's website and
pick off one you like the looks of.
