How generate 30 PWM singals for a multilevel MOSFET inverter using MAX II starter kit
linhainpu
Newbie level 1
Newbie level 1
I want a dsp2812 to generate three PWM signals and a I/O singal and input them to the **broken link removed**. and is there a neccessity to make a middle circuit between two kits? Also, I want to generate 30 PWM singals for a multilevel MOSFET inverter using MAX II starter kit by the inputs from the dsp2812 kit. Is that possible? If not, please to introduce a better kit to me.
Beside, how to connect a DSP2812 starter kit and a MAX II starter kit? I think a synchronous frequency singal is important for the cooperation of two start kits. How to generate the synchronous using the dap2812 kit? Any suggestion will be better. Look forward to you reply. Thanks
