quan228228
Full Member level 4
fpga hold time violation
When i run FPGA, I found some hold time violation.
how can fix them?
Thanks!
David
how can fix them?
Thanks!
David
In FPGA design some reason can cause the setup problems. i think the first task is to find out what caused the problem through reads yout sta report. when you find it you can try to fix it as the following way.quan228228 said:Thanks!
then how about setup time in FPGA?
David
