- Joined
- Jul 4, 2009
- Messages
- 16,507
- Helped
- 5,157
- Reputation
- 10,347
- Reaction score
- 5,208
- Trophy points
- 1,393
- Location
- Aberdyfi, West Wales, UK
- Activity points
- 139,590
That's the very good observation. Infact, the 78L08 got hot instantly along with 7812 from power supply just as I started first test (only power supply section soldered, no VFO, MC, N whatsoever). That's the first thing I fixed already, I just somehow forget to note that in my post.WARNING: not only is the positive end of the tuning control not connected to a voltage (which I think is what you fixed) but the voltage regulator has the wrong connections. Check the connections on the 78L08, with the legs facing towards you and the flat side facing upwards, they are OUT, GND, IN from left to right. If you didn't notice that before powering up, you may have damaged the 78L08 but everything else should have survived.
Those are samples recorded just (at the middle of the night) with mobile phone. The setup is new receiver board with a few meters transformer wire antenna (around the room) and GND connected (kinda accidentally, but it made signal louder) to oscilloscope GND/earth (but the oscilloscope input was NOT connected to the board during recording). The board was powered through the 7812 vreg.When you say 'distortions', can you describe exactly what you can hear or maybe record a few seconds of audio as you tune across the band and post it here please. Its easier to diagnose a problem when you can hear what you are observing there.
Until I purchased the right kind of shortwave radio, I only heard SSB voices sounding like Donald Duck on my cheap radios
Unfortunatelly this coil is in SMD package. The circuit description says that 1210 SMD coil is required for the stability of the VFO. It's said that the author experimented even with various SMD cases and chosen 1210 as the best one.On the assumption that you were hearing CW properly, you need to make the tuning range slightly higher by reducing the inductance of the tuning coil, the one between pins 1 and 4 of the MC3361. It probably only needs a slight adjustment so try spreading the turns slightly wider and see if it helps.
There is nothing in the VFO to stabilize it at all. I suspect what the author found was that after 30 minutes the temperature of the MC3361 stabilized and that has some influence on the frequency. The 1210 should be no better than any other type, the number just refers to the length and width of the package but it is only the inductance that really matters.
So you say that was a normal AM radio?The strange music will be from one of the commercial broadcast stations on a nearby frequency. Direct conversion receivers can pick them up but have difficulty recovering the audio frequencies. If you tune through an AM station you should hear a high pitched whistle which drops to a low pitch them rises again as you continue tuning. The optimum point for music is exactly in the middle of the two tones where the pitch is lowest but without being able to lock to the signal, you will find it difficult to get the notes to sound right, they will tend to be shifted up or down slightly in pitch.
Isn't this method also used in TV tuners? I am planning to use one in the FM receiiver, afaik they output the "intermediate freq" which I have to somehow convert to audio...It is a 'direct conversion receiver' which means it converts the incoming signal directly down to audio frequencies. In contrast, most receivers are 'Superhetrodyne' types which do it in two or more steps with the middle frequency being fixed so it is easier to filter out adjacent signals and interference. That type of receiver is more complicated to build though.
