Garyl
Full Member level 5
All tests below have been done without any antenna and with 12V (12.31V measured) power supply.
TP1: 8.04V (so the voltage regulator is working, I think...)
TP2: 10.43V (It's the audio amplifier supply voltage, I think...)
PS: I have made those tests with the SSB/CW switch enabled and then disabled, but the results are very similiar....
Input voltage: 12.31V1. Can you measure the voltage between the negative (ground) wire from the power source to TP1 and TP2 please.
5.15V (I tried changing the volume potentiometer but it's still around 5.15V, no more than 0.05V deviation...)2. Please tell me the voltage at pin 5 of the LM386.
Yes, the static sound changes to something different and louder, like a constant noise, vibration..3. with the volume at maximum setting, if you touch TP3 can you hear anything in the loudspeaker? (crackles, buzzing...)
Yes, the static sound changes to a louder and more disorted version of the constant noise/vibration from point 3.4. still with the volume on maximum, if you touch pin 10 of the MC3361 can you hear anything in the loudspeaker?
