GreenAce92
Member level 4
- Joined
- May 6, 2010
- Messages
- 70
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Buffalo, NY
- Activity points
- 2,032
We lost our cat today but I was thinking about a generator that would power a cat's gps collar indefinitely just from everyday movement. Solar panels! Ha.
I was thinking about a rolling ball inside a curved coil, that was attached to the collar. Normally in say those flashlights that you shake and it generates electricity, the magnet is a cylinder, so assuming you'd just round one of these into a ball shape the size of a pea or even smaller, and this was placed inside a coil. Obviously the rolling magnet would not always be facing into the coil as far as the magnetic field goes so it probably wouldn't always produce current when going through the coil...
Another reason this is a bad design I think (aside from being bulky) is that the cat collar wouldn't always stay in the same orientation, where ideally the peak of the curve would be towards the ground where the ball can swivel back and forth.
Thoughts?
Thoughts?
