How does the resolution of PWM affect the application?
hermin
Full Member level 2
How does the resolution of the pwm affect the application? lets say its for motor control, and also the frequency...
Question about PWM
I think your question is a little mixed up.
Would you describe it more?
For driving a motor with PWM first you must decide the frequency of PWM. And it depends on kind of motor you use for this.
After that you should find the minimum duty cycle of PWM that can drive the motor without a noise(sound).
And of course all of these is affected by the load of motor.
    hermin
Re: Question about PWM
hi
this is a good tutorial describes the PWM.
hope that help u
Ahmed
    hermin
The frequency of the PWM absolutely affects the performance of the motor drive.
In general you can say, that the higher the frequency the better the motor control.
When the switching frequency of the PWM is lower the current through the motor is not so smooth, thus, the torque of the motor is n ot smooth as well.
