How does the enable pin(pin 6) of JHD12864E function?
saur
Member level 2
Member level 2
Can anyone tell me how does the enable pin(pin 6) of JHD12864E function?
I mean to ask...that whether it is just to enable the GLCD or whether its function is to latch data using a high to low or low to high transition...
Thank u in advance....
waiting for replies from all of u....
Reactions: saur
    saur
Re: JHD12864E enable pin
One use :-----
There are 2 ways to send commands/data to LCD. --(1) Call a time delay before sending next data/command to an LCD (2) To monitor the busy flag before issuing a command / data to the LCD.
Note:- D7 bit of (command reg) LCD is busy flag .To check that flag you need to make R/S=1 and RS=0 and a low to high pulse for the E pin. After that D7 pin reflects the state of busy flag.
Suppose D7 is connected to P1.7.READY:
SETB P1.7 ;To make P1.7 input port
CLR P2.0 ;RS=0 to access command reg
SETB P2.1 ;R/W = 1 to read command Reg
BACK:
CLR P2.2 ;E=0 to provide low to high pulse
ACALL DELAY ; give some time(pulse time)
SETB P2.2 ; low to high pulse ends
JB P1.7,BACK ; stay till busy flag=0
RET
So that was an example:-
Pin 6 is the Enable pin. When this goes from low to high and then to low again the LCD reads pins 4,5 and 7-14.
Reactions: saur
    saur
Thanks...
Ur replies were very useful....
thanks a lot....
